1 - 10 of 10 Posts
Not that exact tire but similar. I run the 29.5x10.5 PBR which is basically the same size. Bracket racing a 3200 lb car that goes 5.80s-5.90s and 60fts 1.26-1.27 I run 16.5 psi. On a tight track trying to go fast I run 19 psi and go 5.70s and have gone 1.23 60fts. On a typical bracket prepped track it's less likely to blow the tires off with the lower pressure but is faster with the higher pressure if the track will hold it.
Right at 17.5 with a 3550lb car using either 10" or 12" wheels.
17 psi...Brand new 275/60R15 ET drag radials on 8" wheels with no miles.
Friday, hit the strip...Friday TNT's I'm not a fan, but was talked out of Saturday with stuff going on at Cecil (happy too since it rained)
Anywho, typical traction issues with all the street cars on all season tires I guess.
Couldn't get out of the 1.7's (best was 1.5's last outing) Lots having traction issues
Sooooooo, verdict is still out, but going 20psi next time out.
1 - 10 of 10 Posts
