Went to set my timing today and noticed the timing was varying retarding 4-5 degrees as I revved the engine up. I'm using a basic Craftsman induction timing light, no retard knob.
My car has 2 MSD boxes (digital 7 and 6AL) on it and I can trigger it with either the MSD crank trigger (reluctor pickup) or the Accel Dual Sync Distributor (Hall effect). The variation seems approximately the same with any variation of pickup or MSD box. The MSD 6AL seems to have a little less variation (3-4 degrees) then the MSD Digital 7 (4-5 degrees) but basically both retard the timing from idle to 5000+ rpm where it seems to stop moving.
The trigger goes to my Haltech ECU which then sends a trigger signal to the MSD boxes and I can LOCK the timing in the ECU just for setting the timing like I'm trying to do.
Polarity is correct on the MSD crank trigger pickup, I check it twice. The only thing I haven't tried is reversing the wiring on the crank trigger but I don't expect that will do any good since using the Hall effect from the distributor as a trigger is doing the same thing.
The only thing I can think of is the MSD boxes are doing this.
Anyone else have this experience?
Thanks.
Thanks.
