Thanks , how much do you take out and when do you start.I just used the boost regard with the distributor locked out.
[/QUOTE]
[/QUOTE]
Thanks..I looked over my records and that was at 9psi and went high 6's in 100 degree heat on 93 oct.
Later I switched to E50, 1.48 60', [email protected], [email protected] on 15psi in good air. The motor is nothing special, 358w, AFR185, [email protected] .512" $99 HFT cam/lifter from summit, 9.2:1 cr, TorkerII intake, home modded 650dp, E50 fuel, 3400 lbs. This is the graph at 15psi.
Do you have any track times??C & S down loaded there program in my 6al-2 when I bought there blow thru aerosol carb. locked out @32 and ran flawless on engine dyno.
sbf 351/427 twin 62/65's pump gas
still putting it together.
Bill
.020", a very famous tuner said you lose a lot of power if even one cylinder does not fire because of wide gaps and gain very little, if any from wide gaps. I tried .024" and worked with a non resistor plug and it worked, but the same plug in a resistor plug misfired under boost. I went back to .020" and never had another problem. I will say though that I never verified phasing on the rotor. That could have contributed to the problem.Brian...what plug gap did you run on the E50?
