1 - 3 of 3 Posts
I'm trying to install a MSD 8579 in a SBF with a Bank to Bank FAST system. Is there a way I can modify the distributor to change the relationship of the rotor and the reluctor?
why would you do that? or want to do that rather ?
if you turn the engine to 20 BTDC, (distributer out of engine) turn the dist so its mag pickup is hitting a reluctor, and the rotor facing #1, install distributer. then check timing.
1 - 3 of 3 Posts
