1 - 5 of 5 Posts
when the ignition is turned on, should the light on the box be on solid?
i pulled motor to change cam ,stuck motor back in plugged everything in and no fire.
currently running msd 7531 box ,big stuff 3, lt 12 msd magneto and points box ,msd crank trigger
when i hit the ignition the light on the box blinks twice and goes out, which in the indestructions it says that it is a cam sync issue . i dont have or never used a cam sync
wtf i love electronics
it will blink twice when it sees the ignition turned on without the cam sync hooked up,make sure you plugged the crank trigger pick up in the right plug.
if your running a mag dont you have to use the tach wire and hook it up to the mag for a signal from the mag for the msd box to see fire?
1 - 5 of 5 Posts
