1 - 5 of 5 Posts
Do you need to run a separate MAP sensor for the MSD or can you link to the MAP provided in the AMS-1000 package?
OK, I follow that. (now that I looked at the AMS-1000 instruction manual.)
I could use a second SSI 60 connected to the manifold to run only the MSD 7531 boost referenced retard then.
Car is a 67 Olds 442, 425 cu in ,twin 74's, blowthrough.
Just use the SSI map sensor for the wastegate and run a Gm 3 bar map sensor on the intake hooked up to the AMS and MSD box. Unless your planning on more than 29psi then you may have to go up to a 4 or 5 bar SSI map sensor and I dont know if the MSD box is compatible with that.
1 - 5 of 5 Posts
