1 - 1 of 1 Posts
How would you set up the following ???
Leave off the brake with 12 degrees retard (20 degrees) and at 1 second out bring 4 degrees (24 degrees) back in? On some of the slicker tracks I want to kill timing a bit and then bring 4 degrees back in. This is just for conversation it may vary a bit....
Would you use the step retards?
I currently have :
Step 1 at 5700 RPM with 12 degrees and 0.0 sec on/off.
Step 2 is 800 RPM 0 degrees 0 secs on/off
Would you set it up as this?
Step 1 at 5700 RPM 12 degrees 0.0 sec ON 1.0 sec OFF
Step 2 at 5700 RPM 8 degrees 0.0 sec ON 0.0 sec OFF
for step 2 do you have to put an end time?
1 - 1 of 1 Posts
