1 - 3 of 3 Posts
AG Jeff is my Hero
Will there be any EMI issues when mounting a coil like the picture below?. Im making a small panel to mount the two together in the car and was curious if it would cause any issues.
59652
TD 3550
Any MSD system. I would recommended the MSD 8830 coil. Not expensive at all.. Case in point. There was a time i had an issue where as just cranking over the engine prior to it firing.
Noticed the electric shift solenoid on the shifter would pulse back and forth. Yes it had an RF issue. Puzzled for a month. Checked everything 3 times. Finally called MSD. I put the coil on it. Problem vanished immediately. Another note. Keep the coil wire at a minimum.
A Senior Member
In your dirt car probably not, as you don't have a racepak or EFI box by it. (other electronics)
It is best to to have the coil and its associated wiring isolated from all the other wiring for the RFI.
1 - 3 of 3 Posts
