1 - 5 of 5 Posts
I am running a moser fab 9 housing for g body. I ordered it with adjustable lower control arm brackets. My question is what hole in the bracket is close to the factory location. The bracket has 4 holes.
I'm pretty sure the top hole is factory with 3 holes lower than factory. Shouldn't ever really have a need to go higher than stock unless if the car is a 4x4.
Funny I called them before I installed the rear and asked them the same question and was told it was the bottom hole. I knew something wasn't right when I seen the control arm on a angle. U would think the tech would know what is the factory location on the there rears. Thanks trz.
Beyond old
Not necessarily, w/ that bunch.....
1 - 5 of 5 Posts
