Call Art Morrison
After you align the front suspension and get all the dimensions correct at ride height, jack up the chassis with the jack centered under the front crossmember until the front tires just begin to come up off the ground barely. Now recheck your toe in. It MUST not change, if the rack is mounted at the right height, and correct front to rear in relation to the steering arms, it will not change. Do not run the car until this is correct!Now that is some real good infos . Thanks a lot !
how do i check for bumpsteer ?
never done that before
