21 - 25 of 25 Posts
· Registered
as posted before get a decent servo.
undo your servo modification to the trans set and forget.
go online buy from a company called SONNAX.COM.
dirt cheep where you guys are.:rolleyes:
· Registered
to undo the servo mod, there is a return hole under the servo cover there should be a 1/8in plug in the hole pull the plug out and replace with a Sonnax C code servo or a PA servo or even a TCI H servo code they all work great and then set the band at 1-1/2 turns out and forget it.
· Registered
Discussion Starter · #24 ·
I've got a guy picking it up today and he's just going to go throught everything. I bought it fresh but from a guy on a local sight and it was built by an unknown builder so I will fell better having it completely gone through by some who will stand by their work. plus the guy I bought it from is stepping up and having it fixed. thanks for your help.
· Registered
JUST MAKE SURE YOU TELL HIM TO PUT THE BILLET SERVO IN
AND UNDO THE NORMAL SERVO MODUFICATION.
THAT HAS BEEN DONE TO YOUR TRANS.
HAPPY DAYS GO RACING.
21 - 25 of 25 Posts
