1 - 20 of 244 Posts
These will be the rules for the race.If any changes are made they will be done 30 days before race but these are 99.6%.
Gas Passer
Doh!!! Just kidding Skinny! I get it though seriously! There are no rules! Run what ya brung and hope ya brought enuff!!! I like it! James
Discussion Starter #8 (Edited)
N/A
SB 2200lbs
BB conventional head 2600lbs
BB big chief 2700lbs
Nitrous
Small Block inline head: 2650 lbs
Small Block non-inline head: 2700 lbs
deduct 50 for single carb cast intake
Big Block Conventional Style head: 3150 lbs (10.2 deck okay)
Big Block Non- Conventional Head: 3250 lbs (10.2 deck okay)
add 50 lbs for more than one nitrous system on BB
Add 50 lbs for sheet metal intake
Supercharged (SB only)
2800lbs base weight with F1C/Ysi
3000lbs for F1R/Xi
3075lbs for Z trim*
*add 125 lbs. for F1X/XB105
*add 150lbs for F2R
*add 250lbs for F3R – 123mm max inlet
gear drive okay
Single turbo (SB only)
2700lbs base weight with 80 mm
2800lbs base weight with mid frame 85/gt4788
3000lbs* base weight for any (101 or bigger that is being reduced must be reduced to 88mm add 75lbs )
*add 100lbs for LF85 mm
*add 125lbs for 88 mm
*add 150lbs for 91 mm
*add 175lbs for 94 mm
*add 200lbs for 98 mm
Twin Turbo (SB only)
3150lbs base weight max 67 mm
-50 lbs for any tip to tip non reduced entry (twin turbo entry)
(88 mm max turbo on twins must be reduced to 80mm )
add 50 lbs if reduced to 70 mm
add 100lbs if reduced to 76 mm
add 150 lbs if reduced to 80 mm
All boosted entrys with a canted or splayed head add 50 lbs
All 302 based sbf deduct 50 lbs
28 X 10.5 non W slick or 275 drag radial
Leaf springs – 100#
No wheelie bars
Stock Frame rear rails – may be notched
Mufflers required on non- turbo charged entries
Progressives okay
7531 okay
Lexan okay
Fiberglass okay
Tech will make all finial ruleing
Any type auto or manual trans
REDUCERS -OK
NO DUAL POWER ADDERS
- 100# for any modular engine entry
Gas Passer
Damn Skinny, you keep adding weight to the SB Nitrous cars. I think I like post number 1 rules best! Ha! Ha! James
Want make this one go back to work on the 19th. :( y'all have fun.
SOFA KING WHAT?
Looks like $225 entry fee - car/driver/2 crew for Friday and Saturday
Free testing Friday included
Suggestion: Allow single turbos to reduce to 94mm if we are running a 101 or bigger so we wont have to go buy another reducer. That way we can meet the rules of both this race and Ducks outlaw X.
SOFA KING WHAT?
This looks good, gives us ample time to test after winning at Reynolds! Lol!
Glad to hear it Barry! How's my engine doing? LOL
1 - 20 of 244 Posts
