1 - 6 of 6 Posts
Just installed my Msd BTM everything working good. After I cut white wire on BTM my tach at idle will dance around. If I give it a little gas it will level off and read accurate. Any tips on how to correct this????
start from basics...
1) check the routing of the magnetic pick-up cable
( away from all wires )
2) what plug wires and how old ?
3) cranktigger -or distributor?
Just had this problem wth a buddys camaro this weekend. Searched high and low for a problem then borrower a new 6al and was perfect.
Is your box new? If not I would send it back to msd to check out or buy a new one. $209 at summit
1 - 6 of 6 Posts
