I've got a Chevy Lakewood bellhousing for '55-'57 Chevy, with the chassis mounting ear provisions on the side of the bell.
The trans mounting pattern is Chrysler A833.
I want to modify the bottom portion of the bellhousing to come apart so I can swap clutches in the pits without having to fool around with removing all the bolts that hold the bellhousing and block plate together, plus screw with the rear motor mounts.
The plan would be to plasma-cut across the bottom portion of the bellhousing, Tig-weld a flange both halves and then bolt it together with a bunch of 1/2-inch Grade-8 bolts. You used to be able to buy bellhousings like this, but I haven't seen them lately--they were pretty regular in the '60s and '70s.
I've heard that modified bellhousings won't pass tech, and I've also heard that old-school 2-piece bellhousings won't pass tech. (the formed Lakewood style, not the old cast Ansens)
Anybody know for sure what the rule would be? Would they let this fly? It wouldn't be a hack job
-Brad
-Brad
