If the plate is only 1/8" thick, then I would likely not worry too much about pilot engagement. Or remove the stock plate and use only a midplate, then you lose nothing. Does the new cars even have a factory shield between motor and flywheel?
On my car, I have two plates for the fact I needed more room inside the bellhousing. I then used the stock one to weld ears on to make a midplate. The second ring is just that, an open ring so it fits around the flywheel and just spaces the bell outward. There is not enough room behind the flywheel for a full two plates.
