1 - 2 of 2 Posts
I'm running close on my current trans, converter setup, having added a midplate.
If I pull the converter out 3/16", I have 1/16" of solid engagement in the crank. 645 HP SBC, Powerglide.
Will this setup be OK, or is it too marginal to be comfortable with?
Thanks, Pete.
That would be a little too shallow, you would run the risk of the pilot coming out of the crank during operation. I would suggest getting in touch with your converter guy and having him extend the pilot and pads to the dimensions you need. The little investment now could save you some major repairs down the road.
1 - 2 of 2 Posts
