1 - 20 of 75 Posts
ALL RULES STAY THE SAME AS 2008
Liberty's Gears All Motor
  • .400 Pro Tree - 16 Car Qualified Field - Sportsman Ladder (1-9, 2-10)
  • No Power Adders
  • Transmission: Auto Trans and Clutch Assisted Stick OK. Clutchless Transmissions add 150#’s
  • All Cars Must be Shifted Manually – NO Electric or Air Shifters
  • Maximum Tire 29.5 x 10.5 (NO W's allowed) Drag Radials are OK they must not be larger than spec slick
  • Single Carb or Single Throttle Body (EFI)
  • Cast Intake Only (No Sheet Metal Intakes)
  • Rear Suspension: Ladder Bar and Stock Style OK - Four Links add 75#’s - NO Wheelie Bars
  • Stock Frame Rail from Firewall Forward - Bolt-on replacement parts OK. NO Tube Chassis Front End
  • Body Panels: Factory appearing bolt-on replacements ok. NO one piece front ends. OEM style forward facing hood scoop OK, Pro Stock style forward facing hood scoops add 50#s.
  • Glass – Lexan is allowed in the doors, sides and the back
  • Stock Appearing Interior, Including TWO Front Seats
  • Must use Mufflers - No gutting, they should be used as manufactured. Insert mufflers are not allowed, collector mufflers are fine.
  • Class designation - AM followed by your number
Weights
Small Block minimum weight 2950 pounds
Big Block minimum weight 3350 pounds
MUST MEET ALL IHRA RULES INCLUDING LICENSE AND CERTIFICATION
WE RECOMMEND ALL DRIVERS USE ENGINE DIAPERS
How much hp will that motor make? If it is as big as it looks I would say that is at least 800 plus inches. So I am thinking 1600 plus with one carb. That motor could be a class killer.
Just because it is a N/A Engine, it does not mean it will be in All Motor! Don't get all excited yet.
The thing is an intake could end up in all motor so the wording in the rules should be changed so it don't happen. I know if i could afford a one off cast intake as such i would do it since its within the rules as they stand.
I'm sure you or Ben should have the resources to get one, it's not that hard. Just need an intake and a welder oh a couple of carbide bits and tootsie rolls also. Quit:smt089:peeingintake rule.
the possibilitys are endless:p
1 - 20 of 75 Posts
