1 - 20 of 39 Posts
I sell a deutsch bulkhead connector. Uses the same pins as the standard deutsch connector (like MSD). You can use the same tool as a weatherpack connector.
Dennis
See Picture below. Deutsch connectors use either a round pin (as you are using) or a pin simular to a weather pak pin.
$80 for a male and female with pins. 23 position.
Dennis
What is the price for a set of male and female retail for ?
It doesn't use the weather pak pins. It has pins that crimp like the weather pak pins.
will theweather pac pins work in the connectors that come with the round pins ? if so i can use them at home no problem, I have the packard crimpers for them, but I dont think that i can borrow the ones for the round connectors from work
Sorry - Misunderstood. Yes - the connector is the same.
but the conector is the same ? if so i can just order pins, rather that take the shop plires home
I would solder the connections along with crimping them, not a huge amount but just enough to "tin" the crimped connection. Of course you don't want to solder the tangs that lock the pin in the main connector body. But this is just my opinion though. Good luck with your project.
Dennis, would you use the type of connector that you sell to power up nitrous solenoids or would you run a wire direct from the relay to the solenoid? How big of wire can you use on the mil spec type connector? Thanks in advance.
I use all of my connectors to power the nitrous solenoids. They can handle up to a 14 ga wire, but for a NOS solenoid a 16ga wire would be fine.
1 - 20 of 39 Posts
