1 - 20 of 30 Posts
What are you guys using for gas in a mig welder. I'll be welding mostly body panels. Straight Co2 or a 75/25 mix of Co2 argon. What is the difference?
time to go racing yet ?
75/25 stevie wonder can make welds look great ! ..... personally i use c02 and i weld a shit load of 16-18g stuff
75/25
75/25 will produce less spatter. Most newer body panel (mid 80's and newer?) alloys require 75/25 for a structurally sound weld.
I use Co2 only because it does burn hotter. Argon being a heavy gas will absorb some of the heat yet give you better shielding coverage.
I just picked up a bottle of 95% argon 5% oxygen...my welder says he`s been using that mix the last few years with smaller mig wire machines.
Just Sayin Crew V.P.
I have done the argon but as the group has decreed do the 75/25
Strait argon is for aluminum 75/25 is what you need.
If your machine needs co2 to penetrate properly you need a better machine.
1 - 20 of 30 Posts
