1 - 6 of 6 Posts
BYE-BYE RACING
Where can i get a front seal ( the one in front of the bearing) Meziere wants 100.00 for a rebuild all i need is the seal the bearing was only 6.00 seal cant be that much more than 25.00
BYE-BYE RACING
What is the seal manufacture and part number? Usually Applied Industrial Technologies, Motion Industries or Bearing Distributors can get them cheap if you have the part number.
Dont have part# still in pump bearing went out look like water damage . Put in new bearing not leaking yet Just would like a new seal on hand. Thanks
BYE-BYE RACING
$100 is with an armature replacement. Do you need that? Should cost less.
Tryed to by the just the seal no. Thay wanted the hole pump rebuiled for 100.00 NOT the armature is ok hell the brush look new.
BYE-BYE RACING
OK now we are fixed 3 trys to get a seal from Meziere and it is on its way 15.00 .
1 - 6 of 6 Posts
