Chevy - Big Block
The Meziere 300 series high flow pump changed the rules about using electric water pumps on high horsepower street, nitrous, blown, or boosted engines. Delivering 55 gallons per minute of flow, the 300 series pump offers great cooling solutions to high horsepower vehicles. Higher flow rates reduce the chance of detonation.
Features:
Fits big block Chevrolet
Suitable for street or drag strip use - 3000+ hour life expectancy
Show quality finish
High flow design provides 55 gallons per minute free flow rating
All stainless steel hardware included
Light weight. Complete big block Chevy unit weighs only 7.4 pounds!
Stainless steel large diameter main shaft with high performance ceramic seal
Pump will clear cam belt drives and most blower drives
Welded 1-3/4'' inlet connection
Technical Specifications:
Belt Drives: Standard BBC design will clear Jessel belt drives and comparable belt drive systems.
Distributer Belt Drives: Spacers will be necessary to clear belt drive distributor systems.
Finishing The System: This pump is supplied complete with gaskets and hardware. No additional items should be necessary for standard installations.
Amperage draw: Under normal use the pump will draw 11-12 amps.
Overall Height Dimension: The standard pump is 7.28'' long from the mounting surface to the tip of the pump.
Pump Weight: This application weighs 7.4 lbs.
$400
[email protected]
Features:
Show quality finish
$400
[email protected]
