Working on 565 BBC, carb, methanol......trying to get this alittle more consistent, passes in the heat of the day with bad air & around 6000 DA car runs faster, we can't seem to get it to follow the air, good thru the afternoon till around 6:00 pm then its the witching hour, will run slower, ie... 9.16 thru the after noon ... then then throws down a 9.22..... hour later starts the other way .. a 9.18...... 60's are close, da is with in a few hundred, and temp is within 5.......also car is at close to 200 after the pass in the pits, could I need to go up on the jetting? maybe lean?
Running 202's now , any suggestions would be great
