1 - 20 of 21 Posts
Hey guys - not sure what section to file this question under but since I have a turbo car I put it here. I got a 4 gallon summit fuel cell yesterday to hold methanol for my methanol injection setup. I intend to have 50/50 water/methanol or 100% methanol in this tank depending. I heard from a friend though that he had used a plastic tank like this for methanol and the included foam fell apart with methanol in the tank and damaged his pump.
So - does anyone know if the fuel foam found in cells is methanol friendly?
Thanks a ton - I didn't put the tank in yet so all is well. I will pull the foam out tonight!
Sucks because I like the idea of foam in there for baffling but oh well.
1998 Trans Am small tire bracket beater, 1965 GTO street car , 1965 GTO LDR(clone) in progress
There is foam that is safe with methanol. I ran foam in my 3 gallon fuel cell in my firebird for over a year with no issues.
I wanna say that the foam that Jaz Products uses in their cells is the good stuff.
Thats what I had in my car and I never had a problem with it like I said.. And it was in our '57 for like 5 years before that and was still ok.
I know carb's are a little different than injection but I think if you should be ok.
We had a JAZ cell with foam in it. The methanol ate it, got sucked into the feed line, clogged the line, motor went lean, made a big hole in the back of the head.
1 - 20 of 21 Posts
