1 - 8 of 8 Posts
Looking for an idea on what size cells you guys are running . First ever methanol turbo build running front mount tank sbc single turbo mechanic fuel pump HolleyEFI drive to the lanes 1/4mile Racing mostly is 3 gallons enough?
My brother's hot rod (avatar) uses just under a gallon of methanol per run per 1/8th mile. 1/4 mile is another .25 gallon at about 1000pph around 5.3AFR. 3 gallons should get you there unless you go crazy rich or big on boost. What power you planning on making?
How much power you making ? 3 gallons is pushing it just saying
Nothing crazy for power hoping to make about 850hp on about 15-20 pounds of boost if possible
850hp x 1.5 lbs/hp hour x 1 hour/3600seconds x 9 seconds = 3.2lbs of methanol. Add in a burnout, idling and return lane and you might use a gallon of methanol. Idle it lean and mean so it heats up faster.
Even at a BSFC of 2, a 3 gallon tank will be plenty, unless u need more weight to keep the front end down. :)
1 - 8 of 8 Posts
