1 - 13 of 13 Posts
TRZ Rocks!
Used to have one, spent more money on brake clean to clean it than a new wix filter cost. so i traded it for an oil filter cutting tool and use wix filters now.
I like the system one oilfilter, especially if you do something stupid at the track, you can check your motor right there without worrying about cutting open a filter just screws apart. i usually blow out with air hose then dawn and water blow out again until dry then back on i did order 2 screens when i purchased mine so i would have a spare.
T/S 368E
System one is awesome.
I love being able to check at anytime.
I just let it drain in a pan, and then run it through my parts washer.
I've used True Filter and PurePower. Both billet aluminum case with mesh cartridge. Wouldn't have it any other way. Get a can of stoddard solvent to clean them in. You can do several cleanings in a large coffee can full of stoddard solvent.
1 - 13 of 13 Posts
