1 - 7 of 7 Posts
I have a 2004 60hp mercury 4 stroke. Overheat alarm came on 2 weeks ago and I replaced the thermostat and its pissing fine. Has been running fine until yesterday.Went out yesterday and alarm went off until I slowed down and went off a few more times while idling in. Has new water pump also. Any suggestions. Its a steady alarm not a intermitting one.
Check block temp with a melt crayon. Pull lower screens off lower unit make sure you didn't suck sand dirt or weeds in cooling on outboard is simple. Has the impeller ever been changed?
exhaust divider plate gasket. It's an easy fix.
1 - 7 of 7 Posts
