1 - 5 of 5 Posts
I believe I have a WP336....55gpm..1 intlet and one outlet....how should they be plumbed? What is the inlet and what is the outlet? I am running a meziere for the water pump too.
One fitting I would say is on the back side and the other is on the front facing the motor.
The reason I ask..filled the water tank to make sure I don't have a leak in my igloo....and I can't get it to prime or I have it backwards.....UGH....Before I remove and change the direction....I figured I would ask.....
Discussion Starter · #4 ·
Tried it
No luck...anyone ever have problems with a meziere pump? I can hear it run...but it does not seem to pump water. I have tried everything. The pump sits on the same plane as the water tank...but with the amount of water in the tank...it should work. Any advice?
1 - 5 of 5 Posts
