1 - 6 of 6 Posts
got a bbc with a gear drive. where can i find the adapter to mount the fuel pump to the gear assembly. i have seen the adapter plates for the belts but not the gears. any help would be appreciated!! mike
yes. just need to know where to get the adapter that bolts to that housing for the pump. i will have to search their site later. thanks!
It's in the top right corner of the photo. It just doesnt have the pump bolt pattern drilled into it.
Not knowing what gear drive you have, you'll need to know the OD of the cover plate to make sure it's compatible.
Donovan, RCD, and others never did standardize that cover plate size.
its a milodon. thanks!
1 - 6 of 6 Posts
