1 - 4 of 4 Posts
Single disc set ups. Who has used them both and whats the difference.
McLeod soft lock system advertised at 1200 HP
Ram single sintered iron disc setup advertised at 1000 HP
Both systems look the same but the price is no where close.
Has anyone used these at their max hp rating.
I have the Ram unit and have had any problems but I only have about 680-700hp.
Maxamus. I use the single iron with a click over 750hp. 3150lbs. Tim Hyatt does all my clutch work and I've had good luck. This year after seating the new clutch and making the base pressure adjustments I've not touched the clutch. Tim does offer the soft loc assys but this guy will work with and educate on the settings and proper set ups needed. Great guy to deal with. Hyatt Racing.
I have the ram set up in my SBF mustang......the differrence between the 2 is the Mcleod is more adjustable ........uses a fine thread bolt and the Ram uses a course thread bolt....there is twice the adjustablility on the Mcleod
RAM!!!
Customer service is second to none.
We've been using RAM clutches since 1980, and won't use anything else.
Tony
1 - 4 of 4 Posts
