I run a PMS with an A/W intercooler and was wondering if I should be placing the Mass Air Flow sensor before the intercooler or after? I was told that if you place it after the condensation that forms will have a bad effect on the meter and performance of engine? If that is the case what will happen if installed before cooler? What will happen with tune? I was under the impression that it had to be installed after the cooler
