1 - 5 of 5 Posts
Anyone mount their AEM map sensor and IAT in the intake elbow? It's a sheetmetal elbow from Aaron with the bosses on the front that you can drill and tap. Thanks for any info.
The elbow will be fine for the map. I have mine remote mounted, then a line from the elbow to the map.
I have intake air temp in the charge pipe. And I mount it in the pipe most of the time on customer cars.
we have our map taking its signal off the driver side of our elbow about an inch up past the flange. We have a -3 an steel braided line that’s about 16” that goes to the map sensor which is firewall mounted to avoid engine mounted issues from arising
1 - 5 of 5 Posts
