I have a 2003 LS S-10 that I want to change to power windows and locks. I found some doors with them. Can I just change the doors? Is the wiring there from the factory? Any ideas?
Doubt it...completely different wiring harness in the front half...BUT If you could be ever so lucky as to have one that was either missed by all on the assembly line or they ran out of "standard" harnesses ( not likely)....look at your fuse boxes to see if you see Relays for the doors and locks and terminations at those points in the box ...if they are empty then there is your proof
