1 - 4 of 4 Posts
Hi,
I'm rebuilding my engine & I need to replace the main crankshaft bearings in my engine (572 Hemi), as their pretty much shot, good news is crank is fine.
Old bearings are Clevite M Series, which according to their web site have a 0.006" Babbitt lining on a hard steel back & primarily used on engines which have large crankshaft deflection. Under these conditions the bearings have a short life & should be checked frequently '
I can understand the deflection as I was running a 14-71 blower previously, but as I have now switched to Twin turbo, I was thinking of switching to an alternative bearing.
I was looking at the V Series, which according to the Clevite web site have a lead/indium overlay, what ever that means ? or should I go with a K type bearing ?
The more I read, the more I get confused
Can you help in advising me what type of main bearing to go for.
Car will be street driven, 572 KB with Twin 4788's, hp & Boost TBC
Thanks,
Mark . . .
Mike Blackstone at Watson Racing 1-925-609-6409 He built my hemi and lots more Knows his stuff , does Don Little, Steve Wann just to name a couple mopars. Good luck.
The M is a softer coating, if you pull the pan frequently you can run those. The V is harder, used if you make many passes without checking them.
1 - 4 of 4 Posts
