B. Williams
What crank flexes like a wet noodle? Lol
So my best choice would king racing HP series for nitrous motors?
What about the XP series are they good only for naturally aspirated? I didn't get what you about they are hard on the crank.
What crank starts flexing and when depends on alot of factors. Stroke, journal overlap, RPM, weight of rods/pistons, HP..... Non center counterweighted import cranks are obviously not as rigid as say a good Callies, Winberg or Bryant. They all have their place.... just don't be the guy talking shit about "Its the bearings fault" when he's spraying a 50 jet on a $550 Eagle crank....
I prefer the HP bearing but they have a softer material overlay but it can deform under heavy pressure. However if the oil wedge breaks and you do scuff a bearing the soft material is very easy on the crank. The soft material is also more tolerant to debris in the oil.
The XP bearing is good for whatever... I personally prefer to use them in high boost FI engines and certain NA engines but if the oil wedge breaks and you scuff a bearing it's going to mark the crank. The harder material is not as tolerant to debris in the oil.
Not saying that the way I look at this is the only way... its just what works for me.
Will
