1 - 9 of 9 Posts
I have a magnafuel 500 pump & filter as well as a magnafuel regulator & for some reason the fuel guage pegs over 15 psi & if I turn the pump off then on it goes back to 7.5 normall ?? any suggestions??
I have seen this with there regs. before and had to change out the reg. You may want to call them and ask because I have had to turn the pump pressure down on some of there pumps when they where just to much over kill for the system needs.
Talk to Robbie at MagnaFuel... He'll be able to help.
1 - 9 of 9 Posts
