1 - 11 of 11 Posts
Depends a lot on where you live.
Plus that is an open ended question. What about cam bearings? freeze plugs, square or zero decking.
Ya sry to be a little short on info, I'm near the Atlanta area. And yes cam bearings freeze plugs, ect just going to be a street motor the needs to be cleaned up a bit.
$50.00 to R&R cam bearings
$25.00 to R&R freeze plugs.
$75.00 to hot tank and final wash after machining.
$200 to bore and hone, W/O plates.
It could be twice as much or half as much where you live but these are my prices.
I get $125/$150 per hole plus parts to sleeve, if it's 2 Then I will knock a little off.
Here it was,
100 to bake clean it
60 a hole to bore and hone
50 for cam bearings and install
I think it was 40 or 50 for the freeze plugs
200 to balance
225 to line bore
About 100 to deck it
40 to press on the pistons
#Tittipicsmatter !
The last 350 sbc I took to the machine shop cost:
Hot tank clean, bore, new freeze plugs and install cam bearings $225.......I purchased the cam bearings
Zero square the deck $100
1 - 11 of 11 Posts
