1 - 20 of 20 Posts
I am in Austin Tx and looking for someone to do some work on my block.....called Reher but the said they didnt have the lifter bore jig for a raised cam, standard bore center, 10.2 block?
Didnt think I needed anything special..lol...not a new setup just a freshen and change in lifter bore size. Donovan block: new cam bearings, clean up bore and hone, resize lifter bores, etc...
Recommendation?
sounds like you have a .400" raised cam / 10.200 deck block with the lifters in original spacing.
concerning about the lifter bores,
Donovan can do it..
or
I can do it.
but both of us are in southern california.
Discussion Starter · #7 ·
ordinary builder, you are correct that is my set up.
R347GT, it suprised me too.....I think it is the combo of raised cam and stock lifter position, when I asked they said(dont remember how answered the phone at Reher....) Its not one of those raised cam deals is it?...LOL When I said yes they said they didnt have the jig ....had hope that I would not have to send it to Cali. ....Think I will give Mr. Nasier a call ....If anyone else has a suggestion.....post away......
Robert Abbate
Call Arrow Machine in Brenham --- dont know for sure if they can do it but its alot closer then Houston and the quality of work is good as well
you have to find someone that has a BHJ type plate / alignment system
a tobin arp align bore machine for cam bearing tunnels.
not all "cnc" type machines are actually capable of doing the job accurately.
as stated,
donovan can do all/ anything that they actually made themself.
and you know also ,...who else.
1 - 20 of 20 Posts
