1 - 4 of 4 Posts
im running a m/t et street 28x11.50x15, 8 inch rim on a 3300lb malibu. at the track 18.5 psi feels stable on the big end. im thinking my 60ft is suffering from this much tire pressure. 1.57 is typical for a 60ft. should i start at 12-14psi
Your 60 ft times seem pretty decent, but what is your overall ET and MPH?
Have you tried going lower?
I always try to run as much as possible, while still maintaining good performance. It would appear you may be on the high side, but if it works the best from a performance standpoint, I'd leave it.
Thanks,
Jason Moulton
et is 7.15-7.20 95 mph, when i put 100 shot of nos to it the 60ft is the same 1.57 6.92 101mph
1 - 4 of 4 Posts
