What is it at .200" and .300"?this baby is 1.170" base circle intake and 1.207" exhaust
lobes are 281/299 @ .050"
duration at .200" and .300" = forget about it , its insane
duration at .500" lift ... still got 26 degrees there on the intake
So what your getting at is its like the Crane .4467" lobes but for much larger 55mm cores, mild to moderate seat and tons of high lift lobe area.cant spill the beans completely , imagine 26 degrees at .500" lift and work down .
Its close to this lobe in appearance, not sure what your split is for the duration though316 / 336 at .020"
200/208 @ .200"
we have run 2.0 rocker ratio on this intake lobe... 1.014" intake valve lift
