1 - 10 of 10 Posts
Hey, I have a 415 sbc, 13.5-1,brodex heads.
I just took out a Lunati cam 50140 .640 .640 276 284 @.050 106 lsa.
I need a nitrous cam and dont want to re set the springs if posible.
Question is can I get the same cam with a different lsa or am I waisting my time?
Thanks for your help.
Roy.
I am sure you can, just call Lunati or one of their dealers.
In other words, wider lobe seperation, but advance it. This leaves the intake event 'as is', but allows the cylinder to start its blow down sooner.
Your cam now, events @ 50, 4 degrees advanced.
IO 36BTDC IC 60ABDC
EO 72BBDC EC 32ATDC
With a 112LSA, 4 degrees advanced
IN 30/66
EX 78/26
IO 36BTDC IC 60ABDC
EO 72BBDC EC 32ATDC
IN 30/66
EX 78/26
112LSA 8 deg advanced
34/62
82/22
the 50140x is the one you want everything the same but 110 lobe sep i had that lunati back in the day,and i only advanced it 2* for the single plate.8.60 23degree 10" 8" rim
1 - 10 of 10 Posts
