1 - 10 of 10 Posts
Would I be limiting myself if I used Vette or truck manifolds to do twin TC76's on a 403 LS stroker? Max boost will be 20psi. Engine details in my sig. If I do headers, what size primaries should be used?
likely not enough to matter unless your in a class fighting for every last pony.
Thanks. I'm not a class racer. I just do test and tunes.
I just found a GTO that used truck manifolds upside down and backwards. Keeping the AC also. Radiator leaned back a bit to fit a pipe over it. I'm going to try and do it that way.
out of work hair dresser
The truck manifolds have produced 2000HP with a 106mm turbo.
I found some truck manifolds with heat shields for $121 shipped, so those are on the way.
Discussion Starter #9
I may pick some up from you guys. My fabricator may try and do a GTO truck manifold kit.
jus lemme know, i may have a few convertor sets i can cut you off some flanges for the manifolds, then you wouldnt need to vband to em really unless ya want to.i left 3inch stubs on the flanges, plenty pipe still there to build offa.
1 - 10 of 10 Posts
