1 - 20 of 21 Posts
What flywheel do I need to mate a 200r4 to a ls1? I have a mini starter also and will it work? Thanks TC
on the 6.0 trucks with a 4l80 they have a cranskahft spacer and dished flywheel. This will bring the flywheel to a standard SBC hiehgt no adapters need on the converter or transmission.
any 2001 + 6.0 2500 4x4 GM truck with 4l80e transmission. you can get these at the dealer.
Thanks TC
TCI makes an SFI flexplate if you plan to race the car alot.
Pro stock--are TCI the only ones that make a sfi flexplate for the ls style engines-
in the process of looking for one as i am going to start racing a lot soon-
Whats the going cost for the flex plate-
Nick--
Hughes also makes one, I've had one in my car for 2 years with no problems at all. SFI approved, relaitvly inexpensive, and a Th350/400/glide will blot right up with it, I suspect a 200R4 would as well.
The '98 flexplates have both bolt patterns.
Seen one on ebay a lil bit ago both bolt patterns and it was like $85 shipped. and it was an sfi.
1 - 20 of 21 Posts
