Hey guys, I'm building a Nitrous 408ci ls to run some local heads up classes around NC, I'm using some ported LS9/LSA heads and trying to find a suitable cam for my engine. I emailed comp cams and they suggested this cam.
.623 lift
262/274 [email protected]
114 lobe sep
110 int CL.
i also had a cam speced last year for a motor with slightly less compression and not as many rpms
.646 lift
250/264 [email protected]
115 lobe sep
111 int CL
do you guys think any of these cams will work or point me in the right direction to get the right one thanks.
.623 lift
114 lobe sep
110 int CL.
.646 lift
115 lobe sep
111 int CL
