Anyone good with these? I got an issue with my crank/cam I can't seem figure out, made a thread in the electrical section and not having any luck, thought you Ls guys might be able to offer more insight
I think I stumped him, he stopped responding to my thread a while backDanny Holley guru is real good with them and 2stroke on here. Danny will chime in for you.
X2 that is what I'm thinking.Is your tune compatible with the firmware version?
If the tune was saved on an older firmware it could cause issues.
If that is an actual raw signal from either crank or cam, then in no way is that correct or usable.I have a internal billet 24x reactor welded to the crank and air gap was .082 I since modified it to .32,
At first my original sensor was terrible, got a Borg Warner and the issue went to only one miss per pass at the track, then holley told me to put an Ac delco sensor in it and I tried 2, neither would start the car, they sound like they were 180 out
Tune started as v2 when I uploaded the firmware and opened my old tune it said it was adjusting it to be compatible with v3
Only thing changed since it was running fine was heads/intake and the firmware
The system log has issues with the crank and occcasionally the cam, here's one example (I have probably 30)
I've tried 2 other Borg crank sensors
I've tried it without the cam sensor
Tried grounding the coil pack bracket
Tried higher resistance wires
Tried new wires
Changed plugs
Checked wiring
Unplugged boost noids and moved their 12v
New battery for the car
Checked for loose power/ground in harness
Checked air gap
Seems turning the boost up makes it worse(misfire more)
