I finally have some time to stuff the lq4 in my Vega and need to order an external fuel pump and regulator. I currently have 80lb injectors, stock lq4 fuel rails and will be running E85. Fuel line is already -8an and I will be installing a return line as well.
The car will be used 90% for track duty, but I'd still like to be able to drive it to the gas station etc. I'll be running 58psi base pressure and I am aware that the ceiling of the 80lb injectors isn't incredibly high, but should get me over 650rwhp. What is a good external pump and regulator combo that would support 800hp(to give me a little room)?
Also... I haven't seen many photos of how or where aftermarket fuel pressure regulators are plumbed to the stock rails. My lq4 came from a van with a returnless setup. Are most boosted lq4 setups running a static fuel pressure or boost referenced?
