1 - 7 of 7 Posts
I have a built TH400 in a 98 Trans AM turbo car. Pressure at idle in all gears is around 200-210psi (I think 3rd may have been a little lower).
With the trans brake applied it drops to 125psi in P, R and 1st. What could cause this?
I verified voltage when the brake is applied at the solenoid and its fully engeaged. Also checked and moved ground to frame. Fluid is Hygard.
Larry
pressure at idle
P,R,N,1,2. 210
3, 100
Pressure with Trans Brake engaged
R,N,1 125
2, 160
So 3rd being a little lower has turned into half as much. Now you have a leak in 3rd. What is the trans doing or not doing? What do the pressures do at 2000 rpm?
Hutch
Trans was running fine but has been sitting for two months while I swapped k members and made a custom exhaust. Decided to check pressure before getting on the dyno. It did seem to take a lot more rpm to reverse but this is my first th400 and I assumed it was normal for a 4500 stall. Trans has less than 400 miles on it all street no track passes
Pressure seems to stay around the same psi at 2000. Maybe 5 more psi
Discussion Starter #7
Checked the valve for the brake as well as the servo cover, no leaks
1 - 7 of 7 Posts
