1 - 10 of 10 Posts
J&E POWER!!
Is it possible to do anything with my UDXbs3 dash since i lost/can't find my Datalink2 disc? I wanted to try and change some stuff on it and realized i have no clue where the disc was and haven't used it for 3years...is it possible to get a new one or unlock the software so i can mess around with it?
J&E POWER!!
i downloaded that, and it keeps telling me i don't have permission or something. i gotta check it out tomorrow to see exactly what it says.
When you install it make sure you select UDX and VNET. When you first open it, it will ask for a license disk, you dont have one for the UDXBS3 so just select demo mode. Go to File>Open Car Configuration and on the left select VNET and then on the right select UDXBS3. Then connect to your dash, go to Edit>Read VNet Config.
J&E POWER!!
Ok I got hook up to the dash. I want to try to fix my fuel pressure display. No matter what max it will read on my dash is 19.9. It's in the upper left corner, is there a max number that upper left corner can display?
Posted via Mobile Device
J&E POWER!!
Discussion Starter #7
I had a system on my test bench so I tried what you have setup and I got 19.9 too.
Then I changed the display to zero decimals and it worked correctly.
Ill give that a try, thanks!
J&E POWER!!
Discussion Starter #8
It worked, thanks for the help guys!
Try and fix your voltage while your at it.
J&E POWER!!
Discussion Starter #10
I tried, just reads 15 instead of 15.8. I'm gonna try to figure that out tomorrow. O yeah spun a bearing!
1 - 10 of 10 Posts
