1 - 20 of 23 Posts
I hurt my sbf block about a month ago . Get new block and have it prepped , same machinist .... align honed , bored and honed (w/plate's) with an extra .001 clearance (over old block) , decked to match old block .
New bearing's (main , rod , cam) with same clearance's as old block . Also replaced oil pump which raised my oil pressure 10 lbs over old pump . Same rings , looked good and I had installed them new at the beginning of this season . Rotational torque required to turn over new short block - 15 ft pds ..... old set up was 12 ft pds .
Don't know my horsepower .... 2750 lbs , went from high 5.90'[email protected] to low 6.10'[email protected] .
I've been racing for the past month and I am (without a doubt) down a tenth and 2-3 mph !
I'm running a vacuum pump with a low tension ring package (which leads me to the point of this book:) ...... Since the build I've had a small oil leak around rear main area when the engine was not running . Pull engine yesterday to fix leak and find my lost power ...... I can't find ANYTHING to explain my power loss ... other than a leaky (new) rear main seal .... So , my question is would the loss of effectiveness of my vac pump and the added 10 lbs of oil pressure hurt me that much ?
Thanks in advance and sorry for the book :oops:
Do you know how much vac you where pulling last year compare to know ?
a vac pump can give you 15-20 hp
To be honest , going down the track I don't know for sure . I have checked the pump vacuum at the pump (it's the same as always and within spec) . I have a small (cheap) gauge in car that I can't see going down the track :) . Plus I haven't tampered with the relief valve so it will be pulling the same vacuum as before ..... except for the leak's that I've created ...... Thanks !
Disregard this thread !!!!!! I found my hp ....... apparently the machinist DID NOT deck the new block to match the old one . My piston's WERE .020 out of the hole ..... now they are flush ! I should have checked that but I didn't . New head gasket's for an easy fix :supz:
Thanks fastlx !!
SBF TTFMF
Thanks fastlx !!
Wow...20 out of the hole before? What'd you run, a .066 head gasket? Glad you found your missing ponies 8)
TwistedTerror
Glad you figured out the problem...a tenth from having the piston out an extra .020...That's crazy! I think I'll have my heads milled now! ;)
Discussion Starter #8
Yeah , .061's to be exact . I bought my old block fresh out of a machine shop and just figured whoever had it had it decked to 9.480 causing my piston's to be out so much . But everything worked ok with that so I asked my machinist to just match the new block to the old one ....... we're gonna talk :mad: !
But , I'm doing the happy dance for the moment ! :)
You think an .020 thinner gasket is really going to pick it up a tenth and 3mph in the 1/8?
seems to be down quite a bit, it is more probable that it is a ring seal issue.
I just don't see that kind of gain coming from the small increase in compression ratio.
You might see a couple hp but... Not on the order of 30-40hp.
The oil leaks probably aren't helping you pull vacuum either.
What stands out to me is that you used old rings in the new block...
Discussion Starter #11
I didn't realize it until I just went through my log book and the ring's have 116 passes on them now ..... it's a fairly mild bracket engine and my ring's usually last a lot longer than that ...... But , I think I'll go bolt my heads back on and do a leak down .....
ring seal and compression...that's the most important thing in the N/A section:p
Ask up in the prostock thread how long there rings last...the short answer is....not long
Milling the heads may not have the same results as raising the piston outta the hole though!
exactly.....the larger gasket and raised piston ... just like a big old gas port...top ring was sealing good before.....its not now
The first design 351W blocks were 9.480" deck height. Your old block was probably one of those. The newer ones were 9.503". I bet your new block is one of those. I can't remember what year they changed but I think it was '70 or '71?
I used to have a street/bracket '67 Cougar with a '69 block in it. When I stepped up the build once, I got a deal on a set of forged flat tops that were designed for the newer block, & subsequently they were .020" out. I made a fixture out of a 250 Chevy six cylinder aluminum cam gear & chucked them up in my friend's lathe & took .015" off the top (yes I measured the crown thickness first lol). Had them balanced & ran .043" gaskets.
Discussion Starter #16
Thank's for the response's guy's !!
leak down test @ 100 psi
#1 - 7% #2 - 8%
#3 - 6% #4 - 7%
#5 - 8% #6 - 7%
#7 - 9% #8 - 6%
cyl's 2 , 5 and 7 , I could feel a little air moving out of ex. port's , brass hammer tapped the valve's with no change . All the other's I could hear some leakage past the rings .
That seem's pretty good to me ! .....thought's on ring seal ?
BTW , my piston's are latterly gas ported .
Discussion Starter #18
.020" deck difference is a bunch. you will see it in ET.
did you account for weather differences?
All 4 week's that I ran the air was lousy .... very hot and humid . I don't know the exact condition's but my car "settle's in" after the first timed run so 1 week I'd run 6.11-12 and next week it might be a 6.13-.14 . The last passes I made with my old block was similar weather and it was 6.01-02 range .....in good air it's ran 5.92-93 .
If I can get this pig back together I'll find out this weekend if I helped it or not ......................... probably be 6.20's :)
Discussion Starter #19
Welp , when I put it on the trailer a week ago it had just ran a [email protected] . When I put it on the trailer Sat. it just ran a 5.99 @113.8 . The air was quite a bit better but not THAT much better . So , getting the compression back and sealing the engine tight got it right back to where it should be ..... :)
n/a engines don't like loose piston to deck clearances, that's for sure!
1 - 20 of 23 Posts
