1 - 11 of 11 Posts
We have a problem.Motor is 578 ci wedge mopar,making 913hp at 6800rpm and 850 ft tq at 5400 rpm. The car is now going 3 tenths and 7 miles an hour slower. We installed a new 1150 alky carb, 9 convertor 5400 stall and 15x15x33 slicks. Old combo was 1050 gas carb, 14x15x32 slicks, and 9 inch convertor 5800 stall. Shifting motor at 6800 rpm, on the shift change, motor lags for 2.5 to 3 seconds at 6300 before building rpm. I have a fast 170402 dual gas O2 meter, reading 4.5 at idle, can’t seem to get it to playback after a run. Is it possible I am running to much jet, or??? I need help just trying to figure out where to look first. Also I do not have the old parts so I can’t go back to square one. Thanks for any advise. John :confused:
Hemi's ROCK!!!
You are now running a bigger cfm carb, less stall, and taller tires. What did your 60' do? :smt102
Time to change the gears.. if you had a 32" tire that would grow to 33" and now you have a 33" tire that grows to 34" tire i'm sure your trap rpm is down thus your lack of 60ft and mph.. just my .02
Discussion Starter #7
Methanol, 1.8 straight cut glide with brake launch at 4000 on 2 step motor makes 850fttq at 5400 and 913hp at 6800
Discussion Starter #8
gear is a 4.30 weight 2947 with me in it car ran 8.72 156 before the old convertor died was at norwalk last week and car would only g0 9.02 at 148.6
4:56's will put you back in the 7100-7300 range at the big end as well as fix your 60ft time.. i would guess that 7200+/- is where you were going thru the traps before..
Whats the plug telling you ?
1 - 11 of 11 Posts
