1 - 7 of 7 Posts
David,
I would imagine that folks are going to want to know what combination you are running. Im in the same boat here. I think that I have figured out what I am going to run, the question is what cam to put into it.
460 BBC (if I can get away with .030, if not 468)
AFR 305 Heads
~12:1 CR
3500 Lb race weight,
3000 RPM converter on the foot brake (no trans break)
TH400
4.10 gear
32x14 Tire
Victor Jr. Intake Manifold
cross bar plate @ 200 for starters (max 300 shot)
Im looking for a solid flat tappet, a roller is not in the budget.
David, Hope I did not hi-jack your thread :oops:
Bob
my motor is 509 cu 13.5 cr weight of car should be around 3200 lbs th400 not sure on converter but its going to be a nitrous converter. 4.10 gear 29.5x10.5w tire. looking to put about 300 shot thru the motor. My motor made 700 hp with [email protected] 0.50 108 lobe separation
thanks David, I dont figure it should be too hard. there are LOTS of guys here that are WAY smarter than me, here on the board. Im sure Jay or someone will have a good idea where to head.
Bob
1 - 7 of 7 Posts
